How can I tell when Battery is done charging in XPERIA L ?
xperiaeugene
how can i tell when BATTERRY is done charging?
give me SIGNS please
1 ACCEPTED SOLUTION
Uliwooly
if the notification LED is green that mean its at 90% or above, once it reaches 100% you will see 100% next to the battery, also your phone will stop charging, even if the LED is green, it won't charge your phone anymore.
8 REPLIES 8
Uliwooly
ashwin21
duh.. Dizzy_Face
vinay1
My xperia L is charging for long time, when the battery is on 97% from there to reach 100% it is taking more than half an hour.
Any one facing this problem.
profile.country.RO.title
_alexdon_
Try a force restart(power button+vol up until the phone vibrates).
alexdon
vinay1
Tried to force restart (power button+volume up), but phone is not vibrating and restarting as u mentioned.
How much time should i hold power button+volume up to get phone restarted.
_alexdon_
Pressed at the same time,about 10-15 seconds.
alexdon
vinay1
Tried pressing at same for more than 10-15secs but my xpaeria L not restarted.
_alexdon_
In Xperia L it seems this option is not available.You need to remove the battery and put it back in.
alexdon
