Battery problem after update
vinay1
I bought xperia L recently and updated to 4.2.2 and expereincing serious battery drain.
Previously i was uisng xperia Miro and satisfied with the battery performance.
But in xperia L batttery is getting drain and i am not using phone fully and once in a day i need to charge 2times to keep my xperia L alive.
My usage will be of chatting in watss app and facebook that to not continuosly, please if any one faced this problem help me out.
37 REPLIES 37
profile.country.RO.title
_alexdon_
You are welcome.
alexdon
Meezab
Well for me its been more than a month since i updated my phone
But I'm facing this battery problem from past few days
I don't understand what's wrong with my phone
I've to charge it twice a day n even if I charge it completely after some time without even using the phone battery level deducts from 100% to 90%
I don't know why after that the battery level decreases normally but first 10% just go away without being used
Please help me
Meezab
I even removed the battery and then i found increase of 2-3% of charge whic isn't normal
_alexdon_
Repair phone software with sony update service,if you still see problems,you may need a new battery.Anyway,take the phone into service.
alexdon
Meezab
It's been just 4-5 months since I brought this phone and now I need to replace the battery?
This wasn't what I expect from SONY Face_with_rolling_Eyes
anyway the SUS is again upgrading my software when it's already up to date,is this the way it repais the software?
_alexdon_
Yes,it does not matter you are up to date,just repair phone software.Backup important things before the repairing.
alexdon
Meezab
It saya there is a update available ,but when I check through the update centre om my phone its doesn't display any update
is there actually any update for xperia L?
Tags (1)
_alexdon_
Update with Pc companion.
alexdon
Meezab
I'm right now upating my phone via SUS the link you provided in above comment
CheekySham
I have had same experience with dropping first 10% in just few minutes after disconnecting a fully charged phone but somehow it just came back to normal discharging for 10 to 15 days...
I remember that in the same time I had problem with Sony "extension for throw" in Active Application section under settings... I've posted that experience in this forum... I'll find it so try to check that - maybe it will help you..
