One touch control with BRAVIA Sync
jaylward
3,183  Views
Use BRAVIA Sync to control your entire home entertainment system with just your TV remote.
Simply connect your BRAVIA TV to other Sony devices using the power of HDMI™ and you can turn on the whole system, play a disc, even watch movies from your Handycam® camcorder, at the push of a button. Remember this feature only works for Sony devices with BRAVIA Sync.
So if you’re juggling different remote controls or switching between menus on different devices then maybe it’s time you set up BRAVIA Sync – why not get started with our quick online guide below?
How to set up BRAVIA Sync
Taking control of your experience couldn’t be easier:
1. Connect your BRAVIA TV to other Sony devices (e.g. DVD, Blu-ray player, audio system) using HDMI™ cables. Look out for the BRAVIA Sync logo to see what’s compatible.
2. Check HDMI is activated on both your BRAVIA TV and other devices (go to ‘Settings’ > ‘Set-up’ > ‘HDMI Set-up’ on your BRAVIA).
Your home entertainment system will now be synchronised so that you can control it using the BRAVIA Sync features on your BRAVIA TV remote.
One remote & one touch play
Use the BRAVIA Sync controls on your TV remote to co-ordinate your home entertainment – all enjoyed in amazing detail on the big screen and from the comfort of your sofa.
►Play and control connected equipment with One-Touch-Play.
►Turn off the system automatically when you turn off the TV.
►Adjust volume settings and muting of connected speakers.b
►Switch all devices to optimal home cinema performance using the ‘Theatre’ button.
►View, navigate and play Handycam® movies on your BRAVIA TV.
3 Comments
