How to Control Your Set-Top Box with your Sony BRAVIA® Remote Control
Peter_S.
6,524  Views
Eliminate the need for multiple TV controllers by using your Sony BRAVIA® remote to control all your devices connected via HDMI, including your Blu-ray™ player and PlayStation®.
6 Comments
John-Thurman
What is the point in showing what you can do but not showing how.
tonythecat
YES HOW DO YOU DO THIS?????????
Win_88
Specialist
Hi guys,
This depends on the TV and the set, but both support HDMI ARC, there's a good chance you can use Control for HDMI (CEC) to link them and control both sides with one remote.
Look for Bravia Sync on your Sony TV and whatever the equivalent is called on your box.
Win_88
We know how the buttons work but would like to know how to do it. Also does it include sky Q (I have paired sky remote with tv (it turns both on but does not turn tv off - have to use tv remote for that - Why?
Joe_Dohn
Specialist
Bravia Sync is a general feature and it uses the Sony TV remote, not a 3rd-party or set-top box one, and you can find out how to use it on the Sony website.
Superchd
Absolutely pointless video. Impossible to follow
