Hello, i've installed a BDVE880 surround sound system to go along with my sony bravia TV. However, every time i try to turn on the system and the system the tv wont go on. i press a bunch of buttons and get frustrated, and try to turn the tv on manually and with the tv remote, but nothing happens. then about 4 minutes later the tv will turn on. What is the correct way to turn the tv on? This is what i do:
Press BD and press play. THen i press TV and then the AV/O input. THat doesn't work so i press the BD and then AV/O input. THen i press the sony TV remote. Then i leave the room and come back awhile later and it'll turn on when i press the tv remote again. Sometimes i'll manually disconnect the HDMi cable from teh back while i try all this.
Has anyone had issues with this and can anyone walk me thru this?
Thanks,
Daniel
