Sync remote to amp str db 1070
GavinLeeEllison
Have just purchased a RM -PP505 remote control for my Sony STR DB 1070 amp. Can someone PLEASE tell me how to sync the two together? I don't know the code(s) for the amp:smileyconfused:
Tags (1)
1 REPLY 1
Anonymous
Not applicable
Hi there
Try going through this website
http://esupport.sony.com/US/p/model-remote.pl?mdl=RMPP505&LOC=3
Yes, there are no specific code for AMPs/AV Receivers, so you might want to try some of the Sony codes under a trial and error basis till you get one that works.
Hope that helps in any way
