- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
June 2015
June 2015
How to snchronise AVR and TV remote so that they show same volume reading using individual remotes? When TV remote is used to control volume, it always shows a higher volume level on the screen compared to what it shows on the AVR display! I have got Bravia sync enabled and even control my AVR from TV remote (STR-DH550 was in the list of sound systems that can be controlled by TV remote in Sony Settings menu!)
I have got a new X83C hooked to STR-DH550 via HDMI (ARC).
1 ACCEPTED SOLUTION
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2015
June 2015
I don't know exactly your setup, but I've a HTCT350 hooked to a KDL42W805A and the volume scale the soundbar use is 0-50 while the TV is 0-100 so whenever I change the volume the value shown on the TV is always double than the one shown on the soundbar.
You have just to know it, no way to change it.
2 REPLIES 2
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
June 2015
June 2015
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
July 2015
July 2015
I have the same issue with my new TV and the soundbar display.
Irritating, but just have to live with it I guess!
