Sound bar
Magor226
Sound bar
Hi, I have a Sony SU-B461S sound bar and wondered if these can be connected to any brand of television?
Thanks in advance,
Michael.
5 REPLIES 5
Pascale_F
Moderator
Hi Michael,
Welcome to the community.
Are you sure the model number of your soundbar is SU-B461S?
Thanks,
Pascale
Magor226
Hi Pascale,
Yes i believe so. Its the type that the TV sits in.
I'll attach a few pics.
I've wall mounted my TV now so im wanting to sell it. People are asking if its compatible with their TV, and im not sure.
EdwinaU
Moderator
Hi Michael,
There's a manual for this sound bar here. It would be worth checking this in detail for compatibility to make sure.
Thanks,
Ed
Magor226
Thanks Ed, I'll check it out
profile.country.IT.title
metstur
I have one issue with my LG soundbar and Sony TV.
The bar has only optical, USB and analogical ports.
I have connected the bar to the TV (Bravia X8308C) with the optical cable.
Bar works when TV is on Digital IN. If I move to HDMI 1, where I have connected SKY Decoder, no soud is coming.
Is there something I can do or simply the bar is not supported by the TV since I do not have the chance to connect it through one HDMI Arc cable?
Grazie
Matteo
