sony svr-hdt500 freeview+hd recorder - aspect ratio
dereves
hi. I use this with my sony HD TV. older programs broadcast are automatically resized to fit with the TV but using the recorder they are not, they still appear in the original/smaller format. I have set the HD recorder to the 16:9 ratio and the 'full' setting, but it is not resized automatically. Does anyone else have this problem with this configuration? I know that I can change it using the TVs remote, but surely this should be done automatically by the recorder itself. Thank. Derek.
Tags (1)
1 ACCEPTED SOLUTION
Bravia55HX
Hi Derek,
deffo not a firmware issue, im not sure but i think the recorder will only record older shows in their native size, if you watch on tv for instance The Darling Buds Of May, the credits at the beginning are 4;3 then the tv stretches it to fit 16;9 when the show starts this is done with the tv's settings to fit the screen, i dont believe the recorder can do this and only records it in its sent broadcast 4;3 size.
4 REPLIES 4
KDL-CX520
Hello,
Please check the firmware version which should be the latest version 4.21.r8585
The Sony latest download page is linked here http://support.sony-europe.com/tvhc/downloads/downloads.aspx?site=odw_en_GB&f=svr_8585&m=SVR-HDT500
dereves
Thanks, but the latest firmware is in place, but the situation is the same. thanks for your reply. Derek.
Bravia55HX
Hi Derek,
dereves
Thanks, I think that you are correct, and only applies to older programs. Will have to live with this I think. Derek.
