Sony STR-DH820
OPGELOST
PositiveIT
Nieuw
Sony STR-DH820
Hi there,
I wonder if anybody out there can help, I have this amplifier connected to a PC through HDMI and then through to a projector, works fine when I play say YouTube video, however if I connect to say Netflicks or SkyGO then the auto sync keeps searching for a HDMI Source, even though I have fixed the source to HDMI1 it just does not want to stay on that source for some reason?
I have ruled out all the kit bypassing the Sony Amplifier and everything works fine!!
Any help would be appreciated, Thanks Jason
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
Pascale_F
Moderator
Hi PositiveIT,
Welcome to the Community.
It might be best to contact Sony Support about this.
Thanks,
Pascale
2 ANTWOORDEN 2
Pascale_F
Moderator
Hi PositiveIT,
Thanks,
Pascale
PositiveIT
Nieuw
Thank you Pascale, sure will give that a try!!!
