The DVD drive on my HDD/DVD Recorder (Model RDR-HXD890) is having some problems. When I put a blank DVD +/- R/RW into the drive the message comes up that it is loading. After about three minutes the message goes and if I then press the Title List button it confirms that the disc is loaded. If I then try to copy a title I have recorded on the HDD to the DVD drive, the message says the disc is non recordable. I have tried formatting a brand new blank DVD disc +/- RW and after about 5 minutes I get a message saying the disc cannot be formatted. Has anybody got any suggestions. I have used a lens cleaner and all other aspects of the 890 are fine. Help, please!
Some DVD discs brand maker are not compatible with your Sony device, check the manual about which disc brand names are compatible
