Hi, the remote control to my BDV-L600 does not work, except for the volume adjustment. It's quite new, but to make sure I have also changed batteries. Strange.. Maybe I have locked in in some way?
Happy if someone has an idea,
Arild
its more than likely its faulty although a rare occurance, i suggest if the player is still under warranty speak to your dealer about exchanging the remote for another.
failing that just Google it and there should be a list of suppliers that will supply a new one.
