Sony VPL-EX3 power light is not on hence the projector is not working. The power supply lead is ok.
Can anyone advise as I do not want to send it for repair if it is not worth fixing.
Thank you.
how do you know the lead is working?, in any event it sounds like a power supply board failure and would need examination by a service engineer.
Hello RobertEdwin,
If the main power fuse is ok, then the most probability will be Lamp failure
