Manual
shrimpery
Manual
Hi there.  I've managed to loose my instruction manual for the latest model BluRay.  Can I download one?
1 ACCEPTED SOLUTION
Blencogo
Yes, you can.
Hover your mouse pointer over the Tab 'Support' in the black bar at the top of this page and choose 'Online Support'.
Enter your model into the 'Search by Model Number' box - you don't say which model you have, so enter the correct model BDP-Sxxx
Your Blu-ray Player's support page will open and there is a tab for User Manuals.
:wink:
1 REPLY 1
Blencogo
Yes, you can.
:wink:
