HT-ST5000 Sound Bar Compatible WiFi Speakers
Kwt1947
Does anyone know if Sony have any multi room speakers that are compatible with this sound Bar? Thanks
2 REPLIES 2
Sean_Mc
Moderator
Hi there,
I believe the SRS-ZR5 speaker is compatible. More details here.
Perhaps someone else in the community may be able to suggest other options.
Best wishes,
Sean Mc
LightFoot
Specialist
Hi @Kwt1947
This is the reason I rejected the HT-ST5000 as I believe there are no true surround speakers available or likely to be. I opted for the HT-ZF9 with the SA-Z9R rear speakers.
