ht-gt1 soundbar light issue
I cant turn off the blue light illuminator on the speaker.
The power-off button on the remote places the system into standby, the blue light goes out then around 5-10 seconds later comes back on and randomly flashes.
If i turn the system off using the speaker illuminator button on the remote, the same thing happens.
I cant believe for one minute this is a design feature. Who on earth wants there room filled with blue neon light when no-one present?
Any advice on how i can prevent the blue light from coming and remaining on when the system is off/in standby?
The only way i can see is cut the power. Not ideal in its desired location.
Thanks, paul
Tags (1)
1 REPLY 1
kaleb500
Try pressing the 'display' button on the remote while in standby. It should disable the lights and the LCD.
