- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Finalisation problems
I'm having problems loading a 'finalised' DVD which worked perfectly prior to the finalisation process.
This was originally burned and latterly finalised using a SONY DVD Recorder - Any ideas as to why this has happened and a solution on how to get it back will be greatfully received...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have experienced exactly the same problem with the Sony RDR-VX450.
This error seem to occur when using DVD+RW and DVD+R disks, and/or using the recorder in VR mode, which suggests there is a problem with the disk finalisation process which is automatic if you use DVD+ disks.
The advanced features of DVD+ do not appear to be correctly implemented in VR mode on this machine, perhaps indicating an internal software problem.
I would suggest you change to DVD-RW and DVD-R disks only, and change the default disk format mode to Video instead of VR: this seems to resolve the issue. Disk finalisation, when performed manually on DVD-RW disks recorded in Video mode, works normally; such disks are also no longer corrupted or automatically erased.
