We have a DAV150G surround sound system, of which the dvd needs replacing. Is it possible to replace this with a newer dvd without replacing the entire system? I am not the most technical person on earth but there looks to be a problem with speaker connections from old to new. Can anyone help pls.
unfortunately this is an all in one dedicated system and unless you can soarce another exactly the same as the main drive unit your stuck.
Thanks for that.... not what I wanted to hear . Will now start sourcing a replacement.
