help, new player i keep getting sound gaps on most discs including 3d.... i have the new firmware and i have disabled the hdmi on setting.
upgraded from samsung player that had none of these issues, any ideas.
this is the second one from richer sounds and still havbing problems.
Did you find a solution to this? I have just got the same model and having the same issue!
