AV Sony str-dn 2010 with 46HX800 + PS3
profile.country.el_GR.title
ppetros
Well i recenly buy the str-dn2010 av and connected with tv 46hx800 + PS3. The problem is bravia sync which is not working!!!! I connect the PS3 direct to tv and everything is ok. When i put the 2010 in between then is the problem.
Also in pass thought option in the receiver i can't get to change the hdmi source without start the receiver, which is the case!!
Any help please ? Also i would like official SONY to tell me if there is a problem with the receiver espesially with other sony product (tv,ps3....)
Thanks in advance,
2 REPLIES 2
Catmambo
Contributor
Have you enabled BRAVIA Sync on all the devices, sometimes you have to enable it on the amp.
No reason why it shouldn't work - I imagine its simply an unchecked box.
ppetros
Thanks.
Solution:
The problem was the PS3. It will remember the previous HDMI settings from a previous TV set. So must reset them. How?
1. Uncheck HDMI control from TV AND PS3.
2. Close tv and PS3.
3. Press ON button from PS3 for 10 sec. It will open and close.
4. One more press ON to PS3. The PS3 opens.
5. Go to PS3->HDMI and press on.
6. From TV go to HDMI search. It will automatic open HDMI ON on the TV and Find PS3.
