I 've bought this BD player with the specific intention of using it as a SACD player. I also have a
STR-DN860 receiver that I use as primary amp and decoder. The connection between them is done through HDMI on the specific SACD/CD HDMI input of the receiver. Both run the latest firmware. I have correctly set from the SACD settings in the BDP-S6700 menu, also the multilayer set to CD/DVD instead of BD. Although at some point my receiver could decode the complete multichannel layer (in A.F.D. mode) - in that moment nothing was displayed on the VFD display of the receiver but the sound was normal from all the 5.1 speaker configuration - now I am not able to make it play as it should no matter what I do. With Music Settings/SACD set to multichannel instead of 2channel STEREO, it only decodes PCM2/0 88KHz - that info I have it on the STR-DN860 receiver, and the sound is plain STEREO, the other speakers are muted. I have tried it with another universal disc player capable of delivering DSD through HDMI and the receiver works fine. I have returned the BD-S6700 unit to service. I wonder if this is an isolated case or is it a firmware issue. I must add that I ran the test with more than one hybrid SACD - with surround track on them. Same problem. Is there anybody with the same issue here?
But it's solved. I am more that confident the original S6700 was OK but the problem was somewhere in the receiver settings.
Hi there
Going by the lack of issues reported about SACD on the BDP-S6700, I would say that your issue is indeed an isolated case. Please let us know how it goes when your player has returned from being repaired.
Cheers
