faulty lens cover - need a replacement
pierreshepherd
I just bought a Sony HX200v camera and on its first outing I lost the lens cover. Apparently this is a pretty common occurence. Can anyone tell me how I can get a replacement, what's the easiest way?
Thanks in advance.
1 ACCEPTED SOLUTION
Mick2011
Hi, welcome to the Sony Forums :slight_smile:
It may be possible to order one by calling the Sony spares people: http://www.sony.co.uk/section/contact/article/id/1237486514070/page/2
The lenscap is prone to go missing if you don't use the tethering strap, and even then it can be a hassle remembering to take it off each time you want to use the camera. Maybe consider using a carry case instead, such as this one http://www.sony.co.uk/product/dcc-cases/lcj-hj
Hope that's of some help.
Cheers
Mick
1 REPLY 1
Mick2011
Cheers
Mick
