Where can I get battery cases for my spare batteries? AS200 camcorder batteries.
Hi micolem71,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Hallo micolem71 ,
Check this: https://www.amazon.com/Think-Tank-Photo-Battery-Case/dp/B00VMLUWG8?ref_=fsclp_pl_dp_6
and this, for more than one battery : https://www.amazon.com/slp/camera-battery-case/q592nukpnqqq8ok
and this: https://www.yoycart.com/Product/526490657457/
This is quite easy if you search for "battery case for sony np-bx1" on the internet...
-John.
Hello John,
Thank you, the plastic boxes appear to be generic, I'll buy one and try it - it may also take a GoPro battery.
Thanks for your help,
Mike.
