- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Loss of BT and Wi-Fi
Hi! After updating to 6.0, this phone has turned into a nightmare! I can not use the Sony Xperia C5 Ultra Dual with Sony SmartWatch 3. When the Bluetootn you Wi-Fi hours in sleep mode all the time lose the connection with your phone. I turn on the phone and see what you Bluetootn Wi-Fi reconnect. On Android 5.1 was not a problem. Recovery through Xperia Companion does not help. Watches are now forced to lie on a shelf and not be used. Firmware: 29.2.B.0.129 (E5533). What to do?
The sister of the same phone. I checked on Android 6.0.
Checked clock Xperia Z3 and everything works fine, but do not work on the C5 Ultra Dual with Android 6.0
problem in a future firmware Will corrected? Or do I change the phone?
I tried to solve the problem as follows:
http://talk.sonymobile.com/t5/Xperia-C5-Ultra/Marshmallow-issues/m-p/1171171#M1902
But it did not help.
If you do not include Bluetooth, the Wi-Fi works well, but without Bluetooth can not use the Sony SmartWatch 3 and sync them with your phone.
Sorry for my english, I'm using Google Translate
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @nnmka, I'm sorry to hear about this.
I just want to make sure that I understand you correctly. Do you mean that you can't use Bluetooth and WiFi at the same time or that the connection with Bluetooth and WiFi drops while the phone is in standby mode?
Are you using a 2.4 GHz WiFi network or a 5 GHz WiFi network? Bluetooth and 2.4 GHz WiFi networks use the same frequency bands. Does your router support 5 GHz network? If it does could you please try and setup a 5 GHz network and see if you experience the same behaviour?
I would recommend rebooting your phone in safe mode to see if a third party application is the cause.
If you have another Bluetooth accessory available could you please try and see if the same thing happens or if it only happens with your Smartwatch 3?
Let me know how it went!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
1. First BT started behaving strange. Before upgrade I used to pair phone with Asus Zenwatch2 and car Bluetooth and it used to work fine. Now it still works with the watch but with car, I am facing issues. It shows paired but as soon as I make a call, the pairing drops. Haven't tried connection with only car without the watch. But earlier it used to work.
2. This is a nightmare. The WiFi stopped working since last week. If you try switching it on, it slides back on its own. I reboot the phone in safe mode, there also it doesn't start smooth. In safe mode also it keeps sliding back but a little slow in switching off. So if I quickly tap on WiFi network while it's there momentarily, it connects. Then if I reboot in normal mode, it works. But the problem resurfaces if I switch off WiFi to save power.
It might be related to some updated app but how do I find out the culprit. Please help, I am losing my patience.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi @Shreyas1 I'm sorry to hear about that :(.
Since it works perfectly from what I understand with your watch there might be compability that is the cause for this behaviour when you have your phone connected to your car. Could you please try and unpair the watch with the phone and only have the car as a paired device?
I'd also recommend that you reboot your phone in safe mode to see if it works better with the car when for example making a call.
How long would you say WiFi stays active before the slider goes back to off both in normal mode and safe mode? Is it 2-3 seconds in normal mode and 10-15 seconds in safe mode?
When the phone has been rebooted in safe mode and you reboot it back to normal mode, does the slider go back to off at the same speed as it did in safe mode or does it stay on for a longer period of time?
Please keep me updated and I will do my best to assist you!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Normal mode - slider goes back in fraction of a second.
Safe mode - it sometimes takes 3-5 seconds and at other times stays in on position. But at other times goes back under a second. So no consistent behavior. It's just that if I try a few times, once I will get enough time for selecting the network.
Once I am connected to WiFi in safe mode, rebooting normally doesn't switch it off. So after connecting to network if I reboot in normal mode, then the WiFi works.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for the update.
This sounds more like a hardware error rather than a software error.
To rule out that it's a software error I would recommend performing a software repair using Xperia Companion.
When you perform a software repair all data stored in the internal storage will be deleted so I recommend that you backup any data that you want to save using Xperia Companion.
If you experience the same behaviour after performing the software repair I'd recommend getting in contact with your Local support and they will be able to assist you with getting the device sent in to a authorized service centre. I'm sorry for any inconvenience this may cause.
Let me know how it works after the software repair!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for getting back to me.
I'm happy to hear that!
Let me know how it goes with the Bluetooth test and I will do my best to assist you.
Have a great weekend!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
