- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi Team,
I am using sony xperia C from last 5 months and now i am facing some issues in this so please provide me the solution for same.
1-: Storage Space Running Out issue
2-: Displaying black lines on photoes in Album section
Thanks!!!
Mukul Dubey
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
About the storage,there is nothing you can do.Just uninstall older apps or try to move to SD,as I understand Xperia C can move apps to SD.
For the album issues,try settings-apps-all-album,clear data.Restart.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
But, How can i move older app to SD Card, please tell me in detail.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If you go to settings-apps-all,look for your app and tap on it.There should be move to internal/SD.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
As per your suggestion for 2nd issue, i have done according to you but the problem exist till now so please provide me best solution because it's not looking good when i want to see any image or photo.
2nd Issue-: Displaying black lines on photoes in Album section
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Try to uninstall updates for album app following the same path.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for the solution but for the first issue, there is no more any solution because i am seeing many persons are facing same problem in Xperia C.
1st issue-: Space storage running out---------------------------- Open
2nd Issue-: Displaying black lines on photoes in Album section----------- Closed
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If you have any more solution for first issue so please resolve it also.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I am not working for Sony.The first issue does not have a permanent fix as the memory is small.You have to uninstall older apps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Install album update of xperia z it works fine on Xperia c. it will resolve your black line problem ......
here is the link
