Anybody have problems with the radio?graves sounds of my terminal up and down with the movement
In that case, you will have to send it back to get it inspected.
Uhm... trying to understand your issue, are you telling me that the volume goes up and down by itself? If you speak spanish, italian or french you can post your question in one of those languages, I can reply anyway
Returning to the issue, if the volume goes up and down automatically that's a feature that can be disabled.
