I have an issue with my TV or my Xbox One X. I suspect the TV has an issue since a forced restart of the OS (Android) on the TV makes the problem dissapear temporarily. After completely being shut of for some time and restarting the devices the problem appears again.
A recorded video of the issue: https://youtu.be/NiTxppq1828
I have tried changing cables, connecting directly to the TV and switching inputs/outputs on my Yamaha receiver but nothing has helped.
Has anyone hade any similar issues with 4K signals to the TV?
Hello @Miller01,
I have seen this before when the HDMI-cable was damaged OR when there was severe magnetic interference around the cable.
- Nic
Ok Good to know!
But the thing that speaks against both these physical suggested faults is the fact that the issue disappears by restarting the TV Android OS.
I have tried other cables with the same issue. What I can try is to also move the xbox to another place and/or keeping all power amplifiers etc turned off. But all these should be magnetically shielded.
