I have a KDL-75855C about six months old..works just fine but, now suddenly it can`t find my Wifi..
it doesn´t find any other Wifi around either..
What`s up du you think ?
tried to switch off the built in Wifi. and then activate again, but nothing happens
when i try to configurate manually it doesn`t find my Wifi
Hope someone can help me
Hold down the On/Off button on the remote for over five seconds, when the set is on, and let it soft reboot.
if this does not fix it, try a Factory Reset.
if that does not fix it, you could contact Sony, or wait for the next software update, or hardwire the Ethernet (or at least use Powerline adaptors for a wired Ethernet connection).
or return the set whence you bought it, as faulty, and get a replacement.
Hi;
Thank`s for your answer, did a factory reset and now it`s up and running again, perfect!
will try the remote thing next time ( if it comes back )
Have a nice day !
