Tv and sound at audio keeps switching.
profile.country.US.title
Vharsquatch
I have an x900h and a tcl ts8011 sound bar connect to arc. Sometimes I have no problem, but most of the time the TV does not recognize the sound bar and it switches between tv audio and sound at audio every 2 seconds until I turn them both off. I need a solution to this.
8 REPLIES 8
Win_88
Specialist
HI
Here's what I'd check:
-Is the TV up to date: https://www.sony.co.uk/electronics/support/lcd-tvs-android-xh90xx_x90xxh_x91xxh_xh92xx-series/kd-55x...
-Have you tried a different cable?
-Try switching eARC off on the TV.
-Turn Bravia Sync off on the TV, and Control for HDMI on the Sound bar, power cycle the two devices, then re-enable them.
Win_88
Vharsquatch
I have tried all of these, no luck.
Win_88
Specialist
What about a factory reset?
Vharsquatch
I think I will have to return it. I did a factory reset, more than once.
Joe_Dohn
Specialist
Maybe try switching the HDMI signal back and forth between Standard and Enhanced and see if that solves it? (Settings - Watching TV - External Inputs - HDMI signal format)
profile.country.GR.title
eteokritis
I have this too with lg soundbar . The only tric is to go to tv audio system and change manually to audio . Then the soundbar sound stays
Joe_Dohn
Specialist
Hey Vharsquatch, any updates after both my suggestions and eteokritis'?
eteokritis
Today, Sony support notified me that an update will be very shortly  released  in order to fix the sound issues !!
