Best TV I've ever had. Yet, the input/info banner keeps popping up randomly. I see this is a problem for others as well. The TV is a - SONY-KDL43WF663BU - and there is no option under Channel Settings to turn off the banner (as well as looking everywhere else). The i+ button doesn't do anything at all, when held down or pressed. I connect it to a PC and I've disabled the sound. I've searched for updates and there are none.
Thank you,
Hi there,
Please try these steps to remove channel info from the screen. Let us know if it helps.
Best wishes,
Ed
Hi, thanks for replying.
I don't have a remote with any of those buttons on. The remote is a - rmt-tx300E - model if that helps.
It seems that quite a few people have the same problem. I think it is being passed over to the technical team.
Thanks,
