I have a Sony KD49X8005CBU 4K TV. Does anyone know if it is compatible with the Sony Touchpad remote RMFTX100. I can't find any reference on the Sony web site.
Thank you.
Hi there
Yes, its compatible. See link below, under Compatibility > Optional Accessories
http://www.sony.co.uk/support/en/content/cnt-specs/KD-49X8005C/list
Cheers
Great.
I don't suppose there is any difference between the remote RMFTX100E in the specs and RMFTX100 on the John Lewis web site?
Thank you once again
Hi there
Your Welcome
I dont think there is a difference. Last time i looked into this, there are 2 versions, an E and a U. Europe and USA. I think some companies miss this off the model number. Either way, it the same and will work.
Cheers
I got my RMFTX100 remote and it works just great. Thank you.
