Laggy channel guide
brphillips358
Laggy channel guide
Hi all,
I have a Sony TL2 TV.
When I search using the guide button, the search is always very laggy. It stalls and then jumps down 3 or 4 channels and so on etc.
Anyone have any remedies for this?
1 REPLY 1
HannahEd01
Hi brphillips358, I couldn't find this model number, could you double-check it? It's essential to suggest a suitable solution.
In the meanwhile, try unplugging the TV from the mains for two minutes while disconnecting any external devices including the antenna, and restart your router at the same time.
