Hello guys
I have this TV and after 2 months ive decided to reset the factory settings as i thought i messed up the input settings and the TV was also acting up a little bit by being a bit slow to respond.
Once the reset was complete the first screen that came up was to set up the touchpad remote but all of a sudden it wouldnt pick it up at all, the remote was perfectly fine before the reset.
I have done all the updates and the verion is 5.0.2- ive done an internal and external cycle, ive even changed batteries just in case but it still wouldnt connect to the remote.
Any ideas for further troubleshooting?
Hi Pav
i found these articles and have tried both methods, unfoirtunately my remote remains dead
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/72587
and
http://sony-eur-eu-en-web--eur.custhelp.com/app/answers/detail/a_id/68153
regards
DAVEBEADLE
Hi Pav
and
regards
DAVEBEADLE
Same problem here, on TWO TVs.
https://community.sony.co.uk/t5/televisions/touchpad-remote-broken-after-factory-reset/td-p/2030222
thanks you guys i actully i try secound option and it works is hard to get red light to blink twice but after 10 times i finlly done it good luck
thanks for this info
