Hi all, I am new to this forum so please treat me gently đ
I have a problem with my Bravia kdl-43w756c tv. I use it sometimes with headphones & when I unplugged them it was stuck in headphone mode with no sound coming out. I can use it with my Sony soundbar but I need to be able to use it normally. I have tried unplugging the power lead but to no avail. Any suggestions will be welcome. Thanks in advance
Hi there
Welcome to the forums
In regards to your issue:
If that doesnt fix the overall problem, can you look at the TVs Sound settings. If your connecting to a Soundbar, the Speakers should be set to 'Audio System'. Also make sure that Headphone/Audio Out is set to 'Headphone'.
Cheers
I am not sure if your issue is fixed. Pleasesee if this helps
Lately, even i had faced this issue. and i was able to fix it with some trial. Here is what i did;
Steps:
Using your standard remote control press "Home" button;
Press Down arrow button and navigate to "Settings"
Then select "System Settings"
Then select "Set-Up" option using down arrow button.
Press Side button and Down arrow button and select option "AV Set-Up"
Then go to "Headphone/Audio Out" option Press Ok button.
Select "Audio Out" Option.
Done. This should fix your issue as soon as you select Audio Out option.
M
