Hi, after update firmware with V.3.155, my TV Optical output is stoped play 6 chanel audio(only 2 chanels).I probe with new version 3.169 and problem is the same...Can i Downgrade the firmware with V.2...?I make Hard Reset the settings and nothing...And What can i do???
Hi there
As there has been a couple of firmware updates since, it is most likely your issue has gone away now. Are you able to confirm if its working again?
Cheers
You will find lots of videos related to it on YouTube, just check them and you will find lots of videos to resolve your issue.
