ARC Connection between X94J and LG SH5 Soundbar
SM2022
I bought this new 55 inch X94J last November and tried to connect it with my LG SH5 soundbar. However, the connection between the two is very unstable. Despite the fact that the soundbar is connected to the TV using a high-quality HDMI cable (HDMI 3), the TV does not detect it and sends OPT signal to the soundbar instead of ARC or HDMI. However, it is possible to get sound through the LG soundbar but to enable that I have to go to Settings -- Display & Sound  - Audio output and turn Audio System Prioritation off and on once. It works seamlessly until the TV is switched off. In fact, when using the External Input settings, the TV shows that it is connected to the LG Soundbar, however, it cannot detect the HDMI connection and defaults the Input to OPT which is annoying as there is no OPT cable connected to the TV or soundbar. I understand that OPT is the default connection on the TV hence, it is using that but it is beyond my understanding as to why can the TV not connect to the soundbar despite the fact that it can see it connected.
I have raised this with Sony Support and they have been absolutely useless, simply stating that it is a compatibility issue, which I cannot understand as the soundbar clearly works with the TV if we fiddle with the prioritisation setting every time!
Has anyone else experienced this? Any suggestions for how to go about fixing this issue?
5 REPLIES 5
SkyNet404
Specialist
Hey @SM2022,
It seems that this soundbar supports ARC, while your TV supports both ARC/eARC, but to make both devices work with each other, make sure that you choose the correct settings.
You need to go to [Settings - Display & Sound - Audio output], and switch eARC mode to OFF, and test it once more.
From what I can see as well your TV also supports A2DP, which means that in theory you can connect it to the soundbar using Bluetooth.
Why don't you try as well, and see if it will work, or not: https://bit.ly/3jgFFWg.
Hope it helps.
SM2022
Switching the eARC mode does not fix it.
Bluetooth would be not able to offer as good sound quality as the wired connection.
I cannot comprehend why TV is unable to sense the HDMI connection despite the fact that I can see the soundbar in the external input tab. It sounds like something to do with the TV OS itself.
profile.country.DK.title
anders234
I have the same issue with xr77 a80j and a beosound stage, nothing helps
royabrown2
Hero
@anders234
If running over ARC, ensure that CEC (Sony call it BraviaSync) is turned on for the TV, and for the Beosound likewise, whatever name B&O give to CEC on their kit.
If running over eARC, ensure that you are using an ‘HDMI with Ethernet’ cable, not just a plain HDMI one.
Piscie
Hey @anders234, could you test other HDMI cable as well and make sure your TV is running on the latest software version?
