Alarming sound’s when first switched on
EddieDrummond
My new TV makes explosive sounds when first switched on.
4 REPLIES 4
royabrown2
Hero
@EddieDrummond
That’s not right. Get on to your retailer to get the set looked at, or replaced.
Anonymous
Not applicable
Yup, that's definitely not right. But does it seems like an Alarm or something that you might've set on the TV set itself? Or is like a static buzzing sound from the TV internal components? And what's the model of your TV?
EddieDrummond
Got the matter sorted thanks. I believe it was my Freesat box causing the problem. I occasionally reboot this together with a better quality HDMI lead. Fingers cut hasn’t happened since.
EddieDrummond
Sony sent an engineer to examine the TV and it appeared to be the Freesat Humax box. See my previous post. Many thanks for your input.
