I thought I'd create a generic thread to cover off the issues being encountered on the 2015 Bravia Android TVs. I've listed my issues below with fixes / workarounds and responses from support. All comments and solutions welcome!
1) Hot Swap HDMI doesn't work - manifested by no input on HDMI channels 2, 3 and 4 on the KD-49X8305C. Workaround - reset the TV, either by holding down the remote power button for 5 seconds or by switching the TV off at the wall and then back on again. Further details on this thread: https://community.sony.co.uk/t5/televisions/kd-49x8305c-hdmi-2-3-4-inputs-not-working/td-p/1944435
2) HDD Recording doesn't work - error message states a system update is required but none is available when checking. Hopefully this will be fixed soon by a firmware update.
3) Netflix App doesn't work - this seems like the app has been deliberately disabled. So far a support case has only recommended that a factory reset be performed (took two days to get to that cracking piece of advice.....), with no improvement as a result. A temporary (albeit for advanced users only) workaround is provided by MikeLothian on this thread - https://community.sony.co.uk/t5/televisions/netflix-support-for-kd55x8509c-android-tv/td-p/1945360
4) Sound lag and performance issues after the TV (KD-49X8305C) has been on standby for a while - manifested for me as stuttering and sound / picture sync issues in all apps (youtube, amazon instant video etc) and HDMI sources (PS4, seperate YouView box etc). Hopefully this will be fixed in a firmware update, at the moment workarounds involve either changing channels to get the sync to work or in my case having to turn the TV off and then on again at the socket.
As stated previously, all comments welcome. Personally I'm willing to give Sony a couple of weeks to fix this, but if it's not done soon I'll be sending my new TV back for a refund as it's not really fit for purpose.
Hoping to either purchase a Sony KDL-43W805C or the Sony KDL-43W807C, but why is there a difference with the scan frequency on the two models? One is 800hz and the other 900hz, I thought the only difference was that one model was black and the other was silver. Is there any significant quality differences between the 800hz and 900hz models?
I am also concerned about the reported slow android system, is this a real issue? Does the new firmware from Feb 2016 make a big difference in improving the slow anderoid system?
I don't know about those exact models, but I read that the refresh rates given for TV models (a lot of brands) aren't the true refresh rates. For instance, for Sony it's around 4x the true value, my TV said it's got 800Hz, with a Sony patented name for it (can't remember what it's called) when infact the true value is 200Hz.
Hope this helps when comparing to other models and previous TV's which had 50 or 100Hz.
With regards to the OS, I've had minimal issues, UK firmware, it's not really satisfactory still. Considering it's now 2016 and a £900 TV, you'd expect it to be flawless, with turning the TV fully off, rather than standby, every few days it's a lot better.
But you could get a TV that suddenly bricks on a new firmware like other people have had, and then you'd be a lot less happy than I am.
I am using VyprVPN, who has an app for Android TV. Easy as selecting the country you want to "be in" and click connect... Tested with Netflix - works perfectly. Check it out at https://www.goldenfrog.com/vyprvpn
chbjerg wrote:I am using VyprVPN, who has an app for Android TV. Easy as selecting the country you want to "be in" and click connect...
Don't forget to switch off automatic Sony Firmware updates otherwise you could get an update not intended for you.
@and3ys HDD recording and pip/pap where released all over europe yesterday well in advance of the planned Feb 29th, so finger crossed for you guys in UK
And it has been pulled already again as well as it caused new issues with a certain brand CI+ module (Smit) and provider (old ziggo area). Zapping to encoded channels caused lockups (blackscreen and audio from previous channel).
There are some workarounds (disabling interactive tv and changing channels through the guide) but yeah, another screwup.
Hi Flipstone and others
To clarrify - The OTA has been stopped. The update is still available for all EU countries via download (usb) except for the Netherlands.
Cheers
@cjazz2016 wrote:Hoping to either purchase a Sony KDL-43W805C or the Sony KDL-43W807C, but why is there a difference with the scan frequency on the two models? One is 800hz and the other 900hz, I thought the only difference was that one model was black and the other was silver. Is there any significant quality differences between the 800hz and 900hz models?
I am also concerned about the reported slow android system, is this a real issue? Does the new firmware from Feb 2016 make a big difference in improving the slow Android system?
You will see no difference with the scan frequency settings.
And despite Sony's assurances to the contrary, I remain sceptical that there is any difference, as it would not make the remotest manufacturing or marketing sense to muddy the water of the aesthetic choices of bezel and stand colour with minor manufacturing, or even just configuration, differences.
On the other hand, it did not make the remotest manufacturing or marketing sense to release these TVs in the initial state they were in, so what do I know?
These sets, even on YouView, go perfectly fast enough after a restart, which is simply and painlessly achieved by a ten-second press of the On button on the remote, something you can quickly and easily do if the set goes sludgy on you. Sony are anyway working to resolve the sludginess, release by release, and one day they may even get there.
