What is a better choice to take astrophotos: ILCE-9II or ILCE-7sIII?
pitokrata
My priorities are to have good photos with low illumination (including sky) and also to be able to have good action photos with fast moving objects.
Now I have an ILCE-7s which is perfect in darkness but not as good when I take photos on a volleyball match. Also, the resolution is sometimes insufficient when I take astrophotos.
What would be the better choice when I am switching to a newest type of cameras?
1 REPLY 1
Peter_S.
Hi pitokrata,
I think the A7SM3 would be the better choice since it will serve you well with its high ISO and low noise.
But if you really looking for a higher resolution the better go for the A9M2.
So in principle you have to answer this question for you:
Do I need more resolution?
Yes > A9M2
No > A7SM3
Cheers
