Sony Wireless Remote Commander RMT-DSLR2
mshcah
I am considering getting this remote commander to use with my NEX-7.
Does anyone know its range? How far can I be from the camera for it to work (assuming unrestricted line of sight)?
I only plan to use it for still shots, not video. Would it be a good buy or are there better alternatives?
Thanks in advance for any advice!
1 ACCEPTED SOLUTION
Blencogo
It says in this review:-
https://www.youtube.com/watch?v=7jV9aYVn_FQ
the range is 15 to 30 feet (4.5 to 9 m) line-of-sight to the sensor on the front of the camera.
If you are using it for single shots, there is a much cheaper alternative here:-
https://www.amazon.co.uk/Wireless-Infrared-Control-Milnolta-IRMT-DSLR1/dp/B002VM49KC/ref=sr_1_1?ie=U...
2 REPLIES 2
Blencogo
mshcah
Thank you very much!
