Hello I was wondering if anyone knows what flashes are compatible with the Sony a9?
Thanks josie
Hello @Josieowen2,
you can see the compatible flashes on this compatibility-checker-website from Sony: http://support.d-imaging.sony.co.jp/www/cscs/accessories/compatibility.php?area=us&lang=en&mdl=ILCE-...
Some of the flashes shown on this site show a little icon in the lower left corner, which is the adapter needed in case you want to use that particular flash.
If there is no adapter listed, it works right away on the cameras accessory shoe.
- Nic
