При входе в меню камеры, при просмотре снимков либо при нажатии на кнопку Fn возникает ***** - камера начинает с дикой скоростью бегать по пунктам меню по кругу - как будто кто-то зажал кнопку "вправо". При этом сама кнопка не залипла, нажимается без проблем. При навигации по другим разделам камеры глюк не проявляется. Залил последнюю версию прошивки - не помогает.
Для наглядности записал процесс на видео
Hi @Yuri_Novy and welcome to the UK forum
Please try and post in English here if you can.
Your post translates as
"When entering the camera menu, when viewing pictures or when pressing the Fn button, ***** occurs - the camera starts to run around the menu items at a wild speed in a circle - as if someone had pressed the "right" button. In this case, the button itself is not stuck, it is pressed without problems. When navigating through other sections of the camera, the glitch does not appear. Filled the latest firmware version - does not help. For clarity, I recorded the process on video"
Are you sure there is nothing stuck in or near one of the buttons?
If you have already tried resetting the camera or updating the firmware
and that hasn't helped then its probably best to contact Sony Support.
What country are you in?
