Memory Card for A3000
morten56
I have purchased an SDHC 1 memory card (8GB) for my new camera.
When installing the card, display says "reinsert MC". Card might need formatting, but I cant access this feature. What am I doing wrong ?
3 REPLIES 3
Blencogo
Hi morten56 and welcome.
It should take a SDHC Card OK.  What make of card are you using?
I presume it is inserted correctly?
Have you got an old SD card to try to check the slot is working OK?
:thinking:
morten56
I am using an 8GB SDHC 1 card, called Sandisc
profile.country.EE.title
JessicaGO
I am having the same problem with aSanDisk card/the same model! Did you find one that works yet? I need to order a new one...
