LR lens correction does not show my 16-50mm lens
iprior
Can I do something to sort this?    thanks
2 REPLIES 2
Mick_D
Moderator
Hi @iprior
Adobe regularly update their lens profiles and you should check to see you have the latest version of the app. Is your version very old?
Your 16-50 is unlikely to be so new it's not listed yet, so make sure you're looking through all of the options for this lens; it may be further down the list (eg 'Sony DT 16-50') or under a different mount menu (Sony E) – I'd be fairly confident in stating all these lens versions carry the same optics, so any of their listed profiles should work.
Mick
iprior
anks...when you say look down the list. I assume you mean the list in LR? The lens I used is a 16-50mm .The only Sony lens that shows is a Sont DT 18-200mm. It does affect the image when selected.   regards ian
