Lens fitting
rfoulkes
Lens fitting
Hi. I have a Sony Alpha A77 and various lenses. In the event of something happening to the body is there an adapter available that would allow the fitting of my lenses to a fukll frame body?
1 ACCEPTED SOLUTION
GordonT
4 REPLIES 4
TheRealOG
@rfoulkes can you give more details on what exactly you mean by (In the event of something happening to the body)!! 😅
rfoulkes
Well, a bit obvious really. I mean if I lost or damaged my A77 body. Sony do not seem to make an A fitting DSLR body anymore, only E fitting full frame.
GordonT
TheGOAT
@rfoulkes I guess you can get an adapter you can use to link them together.
