Dear all,
I use a good old Sony rx1 mk2 and the feature in subject line results in superb shots even in extremely low light situations.
However, I cannot seem to find this feature on my new A7r4. Is it renamed, well hidden or simply not available?
Thanks a lot for your suggestions.
Z
Hi zolliejunk,
These functions are available with your A7RM4 as well. You can find them in the menu named as:
Long exposure noise reduction (https://helpguide.sony.net/ilc/1930/v1/en/contents/TP0002728100.html)
High ISO noise reduction (https://helpguide.sony.net/ilc/1930/v1/en/contents/TP0002711864.html)
Cheers
Hi @zolliejunk
I've been comparing the description of the feature on both cameras (in Sony's online help guide), but I can't see what would indicate that a different mechanism is used. So may I ask you where that was indicated?
As far as I can see, High ISO NR is exactly the same on both models.
DSC-RX10M2: https://helpguide.sony.net/dsc/1540/v1/en/contents/TP0000823559.html
ILCE-7RM4: https://helpguide.sony.net/ilc/1930/v1/en/contents/TP0002711864.html
Win_88
