profile.country.DK.title
Ricmo1
Imaging Edge
Is Remote Shooting using Imaging Edge not supported in Denmark?
I would like to view the picture from a Alpha 7II on an Mac computer screen (with version Os 10.11.6 software) before taking the picture.
1 REPLY 1
iancandler
It should work fine, connect the USB lead to your camera then in settings/toolbox set it so its on PC REMOTE, then start the remote software
