Alpha 1 and A6700 deleting group when first image protected
GordonT
If l set the cameras to group photos and take a burst of images, then protect the first image they won't let me delete the group. If l protect any other image in the group, and not the first, they will let me delete the group.
Seems strange feature, which l note the A9iii doesn't do, it lets you protect the first and delete the group.
It would be nice to get this 'fixed' in the Software updates.
6 REPLIES 6
GordonT
Appears to be fixed with A1 update v2.00 !! Thanks to Sony.
GordonT
Just update A6700 to v1.3 but unfortunately the 'issue' isn't fixed.
TheMaze
Hey @GordonT
I think it's more logical for the firmware that it doesn't allow deleting a group that has a protected photo at all, whether it's the first one or not
GordonT
That's not the way l use it. I take a burst of images at 20 or 30fps, then find the best individual frames,  protect them and then delete the rest of the group. Works well for me.
SatoruGojo
Hey @GordonT, you can try taking the batteries out for a min and then reinsert them.
Try to initialize the camera as well: Reset
GordonT
Can l ask what this will achieve ? Is it related to the A1, which is working perfectly for what l need, or the A6700 ?
