Does anyone know if the A7riii battery is compatible with the A7rii?
I'm hoping to use the camera for longer between recharging...
Hello @uganda4,
according to the spec-sheet, the A7Rm3 uses the NP-FZ100 battery, which according to the compatibility-chart is not compatible with the A7Rm2.
- Nic
Thankyou
