A7R111
helenmsugrue
A7R111
Hello
i have a Sony A7R111 I’m reading many articles about the weather sealing on this camera. Can anyone confirm if they’ve experienced problems with weather sealing on this camera. For example should I be taken extra precautions when shooting in the rain. I also enjoy shooting butterfly houses with extreme humility should I be thinking twice about using my camera in these conditions. Is the mark 4 any better? I’d appreciate anyone’s comments.
Thank you
2 REPLIES 2
Peter_S.
Hi helenmsugrue,
The camera is protected against dust and moisture, but not completely protected against dust and splash water. It has no IP classification and therefore can only withstand adverse conditions for a short time.
Therefore, in both cases I would recommend a protective housing that protects the camera from tropical humidity and rain. This also applies to the Mark 4 version.
Cheers
helenmsugrue
Thank you for confirming that. I’m glad I’ve always taken the bother to protect the camera.
